NEED torque specs[top/bottom]for Polaris Explorer 300!!!
i have looked everywhere, and its a 1998 Polaris Explorer 300... i waited 3 weeks for this last damn bearing to come in, and now i just need the torque settings for the top and bottom end.
anybody out there with this information, PLEASE ASSIST. thanks very very much
Per my 96-97 service manual.
EC25PF/EC28PF Engines
Page 3.16
Step 16: Torque case half attaching bolts in three steps to 17 ft. lbs. (2.3 kg-m) following the pattern on page 3.2
Pattern from Page 3.2
-2----5-
4------3
---1---
Page 3.16
-2----5-
4------3
---1---
before torquing the case together, here is some steps before that should be taken per the SM.
Step 1-9 (my wording) Insure crank is together and aligned!!!!!! Lots of mic'ing to be done here!
Step 10: Clean surfaces and remove crackcase end seals
Step 11: HEAT PTO side of case to HOT to touch
Step 12: Install cracnshaft into heated case
Step 13: HEAT MAG side of case till HOT to touch
Step 14: Place loctite 518 gasket eliminator on ONE of the case halves
Step 15 Reinstall MAG side half
Step 16: Torque to in three step to 17ft lbs following pattern
Step 17 ~ on Piston, Cylinder and so forth.
TLC
Jul 11, 2015 02:28 AM
