95 Sportsman 400 Clutch Question
Old Mar 7, 2006 | 03:24 PM
madhatter801's Avatar
Default 95 Sportsman 400 Clutch Question
I am wondering what color clutch springs I should go with to get the best low and mid range performance from my 1995 Sportsman 400. I have stock exhaust and plan to keep it that way due to noise regulations. I found a kit from HPD, meant for a stock motor, that includes springs and weights for $95. Is this worth it or should I just replace the springs?
Old Mar 7, 2006 | 08:26 PM
crashby's Avatar
get a polaris white primary spring. lots of low end power!!!
Old Mar 7, 2006 | 10:04 PM
Is a polaris white primary spring the same as the white spring that hpd sells?
Old Mar 7, 2006 | 10:50 PM
ftwflh's Avatar
I would take a lok at the weights and if they are worn go with the HPD kit.If they have no play or wear to them get a Polaris green or Dalton blk/white primary spring and either a Aaen blue or HPD violet secondary spring. I have the Dalton-Aaen set up in a buddies 95 400 sportsman and he loves it.
toonces
Oct 16, 2019 12:11 PM
coldnorthpol
Jul 14, 2015 11:22 PM
coolguy420
Jul 10, 2015 01:17 AM
D-Hagz
Jul 4, 2015 02:19 AM
Shifts
Jul 3, 2015 07:59 AM
