Sportsman 600 Problem
Old Mar 12, 2006 | 10:03 PM
cjr854234's Avatar
Default Sportsman 600 Problem
While coming out of a corner or even from a stop I'm feeling some type of slipping. The engine revs up but doesnt seem to move or accelerate like it should. When I let off the throttle and let the engine come down it usually goes back to normal. I checked my belt and its not fraying or coming apart at all. Any suggestion? Just to let you know I haven't made any mods to the clutch and havent really done anything with it since I bought it in early 04.
Old Mar 12, 2006 | 11:41 PM
SCRAMMYTODD's Avatar
If you haven't done anything to the belt since early 04 i would reccomend a new belt and maybe servicing the clutches, i try to do that at least yearly on sleds and my bike
Old Mar 13, 2006 | 09:17 AM
cjr854234's Avatar
Sorry I didn't mention it before but I did have my local dealer replace my belt last june or july.
Old Mar 13, 2006 | 12:20 PM
zerowick's Avatar
you may have an allignment problem between your engine and tranny, check all your mounting bolts for both. I had a broken motor mount bolt on mine early on, not from abuse but from a defective bolt. good luck.
Old Mar 14, 2006 | 08:00 PM
300ex90's Avatar
when i had my sportman 600 i had a similar problem if i stopped on a hill and tried to start again in high gear sometimes it would just rev up and not move then let of the gas put it in low and go... that started happening after it was rolled only problem i ever had though
skittero
35
Mar 1, 2019 12:39 AM
yellowpolaris
Jun 21, 2015 11:13 AM
UPLou
Jun 7, 2015 09:42 AM
May 27, 2015 11:15 AM
PolarisPower500
May 17, 2015 02:28 PM
