05 Sportsman 500 HO AWD problem
Old Mar 13, 2006 | 08:36 PM
domino's Avatar
Default 05 Sportsman 500 HO AWD problem
Last time I rode, switched on the AWD, indicator icon shows up on display, but front end is not pulling. Haven't heard any noises coming from differential, wires and hoses are all intact and undamaged. Anyone else ahd this problem? Any ideas on the problem?
Old Mar 13, 2006 | 08:47 PM
Jayblazer's Avatar
its awd not 4wd so when you turn on the switch the fronts dont just switch on the rear wheels have to slip just a little bit for the fronts to grab and pull thats why you can drive around with it engaged and still be able to turn easily...
Old Mar 13, 2006 | 08:56 PM
domino's Avatar
I do realize that aspect of it, my problem is that when in a mud hole, I only have the rear pulling. The front is not engaging. The front doesn't pull at all.
Old Mar 13, 2006 | 09:40 PM
2manytoys's Avatar
Does your speedo work? Did you check the front diff fluid? If the speedo does not work the awd wont either. If the fluid is low, dirty or over full it will not work. It could also be a bad rollar cage in the front diff.
Old Mar 13, 2006 | 09:51 PM
domino's Avatar
yes, the speedo does work. I didn;t check the fluid yet but I will. Thanks for the advice!
Old Mar 13, 2006 | 10:43 PM
ricknzep's Avatar
just wondering on checking the operation of the 4wd. if you put it on jackstands and throw it in gear will the fronts engage? or do they need to be moving to engage the hubs?
Old Mar 13, 2006 | 10:46 PM
2manytoys's Avatar
If you put it up in the air all 4 should spin when in 4wd.
skittero
35
Mar 1, 2019 12:39 AM
yellowpolaris
Jun 21, 2015 11:13 AM
UPLou
Jun 7, 2015 09:42 AM
May 27, 2015 11:15 AM
PolarisPower500
May 17, 2015 02:28 PM
