Thinkin of buying a Hawkeye 4x4
Old 03-20-2006, 09:58 PM
James1701's Avatar
Default Thinkin of buying a Hawkeye 4x4
Can you get some pictures of that. I would like to see how it looks.
  #22
Old 03-21-2006, 09:30 AM
Teriyaki's Avatar
Form all I have read, this seems like a good quad. My one concern is the air cooled engine. Living in Texas in the hot summer, we sometimes ride our water cooled 500 Scramblers for 6 to 7 hours in a day, and the radiator fan is on most of the time. How reliable will this engine be with just air cooling?
  #23
Old 03-21-2006, 12:43 PM
James1701's Avatar
It should do ok. The 300 does not produce near the heat the 500 does. Just remember to not let the engine stay dirty with mud all the time. That will restrict cooling.
  #24
Old 03-21-2006, 07:29 PM
powerslider's Avatar
There is supposed to be an auxilary oil cooler available but I haven't seen one yet, I think it connects to the oil filter housing as there are two plugs there.
  #25
Old 06-24-2006, 12:00 AM
lb2222's Avatar
Hey guys/gals
I purchased a 2x4 Hawkeye in February of this year..As for it heating up I wouldn't think there would be any problems as I live in South Carolina and we have humidity that is a killer...I weigh 200 lbs and 6 feet tall and power is no problem..mine will run 49 MPH...The only thing I don't care for is the vibration and the dealer tells me this is normal...I had a 1997 Trail Boss prior to this and it was a lot smoother and quieter...Go figure...a two stroke vs four stroke..Has anyone else encountered this vibration? But, overall it so far is a great ATV.
  #26
Old 06-24-2006, 01:01 AM
700vtwinman's Avatar
Originally posted by: Crazyatvspazz
HEY, DONT BE FOOLISH AND BUY A POLARIS. MY FATHER OWNS 2 POLARIS ATVS (TRAILBLAZER AND TRAILBOSS) TIE RODS HAVE WENT ON THEM CHAIN AND PROCKETS GOING ON THEM AFTER 6 MOTHS, IGTION SWITCH GOING AT A YEAR OLD, AND ALOT OF MICS ANOYING THINGS. I PERSONALLY THINK THE HANDLING ON THEM SUCKS. HE HAS A HONDA FOREMAN IN FIVE YEARS ALL WE HAVE DONE IS NORMAL MATIENCE(CHANGE OIL AJUST VALVES). THERE TOUGH AND RELIABLE!!!. IF YOUR GONNA GET A UTILITY GO WITH HONDA AND SAVE YOURSELF ALOT OF TROUBLES DOWN THE ROAD. IAM SORRY IF I PISSED ANY OF YOU POLARIS GUYS OFF BUT THATS MY UN BIEST OPINION. ID GO WITH A RANCHER 350 OR A RECON.<u>Text</u> CRAZYATVSPAZZ
HEY fokes..................please disreguard the above message. The writer hit his head as he fell off his honda......LOL.
  #27
Old 06-24-2006, 01:25 AM
lb2222's Avatar
Opinions are like something else ....everybody has one ....HUH!!! I never encountered any problems with the Trail Boss ....I also had a Kawasaki 220 Bayou...Great Bikes....I also have a 2005 Trail Blazer LE....It will haul ***.
  #28
Old 07-31-2006, 01:19 AM
Vlastic's Avatar
Polaris Hawkeye 4x4 is best thing I have ever ridden in 300 class, sure for the 4,700 US I paid for it. It will stop and get going again on hills so steep I had to sit on front rack just to keep it down (no kidding here). In just two mohts I did 800 miles on it, manytimes going so steep up I didn't not dare to go back down the same way. It will pull small size trees off your trail. Independent suspension at the back get's you another 4" of clearance more. Air cooling means never to worry about antifreeze. It got nice digital display, iluminated at night. Breaks have a grip. It's automatic, I personally don't care much for shifting. If you want machine that is small enough you can flip it back on it's wheels when you all alone somewhere, this is it. (Just do it quick because if you let it be upside down bit too long, motor oil will leak thru air filter out and then you will need to change oil filter and add oil to get it started again.) It's perfect size for teenagers or ladies but will handle my 200 pounds, my mother and my 15 years old nephew on 20 degree slope up sand dune if it has to. Top speed is some 35 in the long run, some 45 max for a short while (you get the feeling you asking too much). The only complain I have is the suspension springs, too hard even for utility ATV, even at it's lowest setting. Also, if you want to ride sand a lot, remember that sand (or deeper snow for that matter) will cut your horse power in half and if you want to fly 40 deegree uphills at 40 miles an hour on paddle tires, you will need bigger engine machine. Other than that I can't believe this 4x4 is under 5,000.
slowgsxr97
09-08-2015 07:33 PM
antiguogrumete
09-05-2015 03:41 AM
snowolson
08-31-2015 03:51 PM
mrmickman123
Technical and How-To Articles
08-30-2015 10:37 PM
Sportsman850
07-31-2015 04:25 PM
Quick Reply: Thinkin of buying a Hawkeye 4x4
