Gorilla winches from Ebay. Check them out!!!
Old Mar 23, 2006 | 12:34 PM
  #51
ttaylor's Avatar
Default Gorilla winches from Ebay. Check them out!!!
Where is a good place to get the winch mount for the Gorilla winches?
Old Mar 23, 2006 | 10:57 PM
  #52
rsking45's Avatar
Just received the winch today,I figure for 100.00 cant go wrong.install dosnt look to be all that hard,but if anyone has any pointers please let us know.
The mounting plate that came with the winch is that just to mount the rollers to the winch or will that also mount to the winch to the atv? winch is going on a 04.5 sp500
Also thanks 2manytoys for the heads up on the winches
Old Mar 23, 2006 | 11:20 PM
  #53
2manytoys's Avatar
rsking,
The mount that you got with the winch will not work. Not even sure what you can use it for but most winch mounts that you can buy will have the mount for the fairlead. As for wiring it is pretty easy. Just make sure when you run all the wires that they are out of the way of moving parts, and ziptie them to the frame. Mount the contactor in the rear where it is out of the way of rocks and mud. Run and mount everything before you hook it to the battery. There is a small red wire on the switch that needs to go to a + power source. It does not explain this in the directions.
Old Mar 23, 2006 | 11:23 PM
  #54
2manytoys's Avatar
ttaylor you can go to rockymountain atv, dennis kirk, parts unlimited, Big buck atv or even ebay. It will use a warn mount.
Old Mar 24, 2006 | 11:20 AM
  #55
ttaylor's Avatar
2manytoys,
Thanks on the places to buy the mount plates.
risking,
Let me know how your install goes. I have the same bike and need to know if there are any problems.
Old Mar 24, 2006 | 07:07 PM
  #56
rsking45's Avatar
Just got off the phone with kfi to order the mount plate. It should be here by thrusday and will install the winch next weekend.
Kinds pissed that they lead one to think that you get the mounting bracket to mount the winch to the atv not the rollers to the winch. For 150.00 i shouldnt be that bent,but I am
Old Mar 24, 2006 | 08:46 PM
  #57
bombaman's Avatar
So the mount that you purchased will fit in the Polaris front hole?
Old Mar 24, 2006 | 10:42 PM
  #58
rsking45's Avatar
that was what I was told so I am hoping so
Rich
Old Mar 25, 2006 | 08:04 AM
  #59
500EFI's Avatar
Originally posted by: 500EFI
Im new to winches and I have a question. Whats the differents between a (Dynamic Brake) and a (Mechanical Brake)?
Thanks
500EFI
Anyone have a answer to the question I ask above! [img]i/expressions/face-icon-small-wink.gif[/img]
500EFI
Old Mar 25, 2006 | 09:09 AM
  #60
cboelman's Avatar
Yes the KFI bramd Mounts fit into the Winch Cubby hole.
Dynamic VS Mechanical:
The Mechanical brake winch (ci/CE) was created for the must have osha required for all types of safety and rescue needs like park rangers and others.
The ci/CE upgrade can also be purchased.
If your winch has a mechanical brake it also has a Dynamic brake.
The ci/CE was originally created for Overseas use and then became a standard for Safety and rescue in the US and have now become available for the Consumer.
The ci/CE is a little harder to freespool that the standard ci
There are two types of brakes commonly used on ATV winches. Most all Warn ATV winches come standard with “Dynamic Braking”. This is a resistance type of brake that is created by the winch motor. This type of brake should hold approximately 500 pounds. If your ATV rolls back on steep inclines, you may want to check your winch controls for proper working order and/or add a mechanical brake to your winch. The mechanical brake is a friction type that is normally optional and is easy to install. The two brakes combined will normally create enough braking energy to be equivalent to the capacity of the winch.
Hope this helped
