transmission oil
Old Apr 3, 2006 | 07:08 PM
EdgeRacing's Avatar
Default transmission oil
will valvoline gear oil work in the tranny case of my 02 scrambler 400 2x4? or do i need to buy the polaris transmission oil???
Old Apr 3, 2006 | 09:18 PM
madmatt1971's Avatar
That depends on what type. You can use anything that meets the required lubricating properties API specification. I know Amsoil makes an oil that will work. Look at the certifications and the API rating and you should be able to find something compatable.
Old Apr 3, 2006 | 10:47 PM
EdgeRacing's Avatar
ok thanks
Old Apr 4, 2006 | 04:07 AM
jimmypsp700's Avatar
I have a 2000 model (Scrambler) and the trans takes (PPS) Polaris Premium Synthetic gear case oil (weight?).
Not sure if this is the same as AGL fluid.
BBScrambler said You can use Amsoil Series 2000 Chain case lube. It works as a substitute to the Polaris AGL fluid.
It doesn't specify the AGL fluid (like my sp700) but its still not Auto Trans fluid such as used in cars.
A lot of different fluids (auto trans to 80w90 gear lube) have been used in the trans' buy others saying they had no problems. (used with their sleds, model "X" atv etc...)
I'm not so sure myself.
I know I won't stray from the (PPD) Polaris Premium Demand Drive (Synthetic) fluid in the front Differential on my sp700.
Jim
Old Apr 4, 2006 | 01:29 PM
EdgeRacing's Avatar
Last summer i used 80w- 90 gear oil. but i was just trying to make sure there wasnt going to be any effects in the long run.... like pre mature wear or anything like that. it seemed to have run fine with the gear oil in it. no problems.
Old Apr 5, 2006 | 02:37 AM
That gear lube seams to be a lot thicker than the polaris PPS.
Jim
Old Apr 5, 2006 | 02:42 AM
EdgeRacing's Avatar
but do you think it hurts anything with it being that thick?
Old Apr 5, 2006 | 02:51 AM
I thick it would, especailly in colder weather.
Old Apr 5, 2006 | 10:22 AM
cornbread2's Avatar
90 weight WILL wear out the trans chain. You can use 90 weight in 1992 and older gearboxes but never in the newer ones.
A good synthetic motor oil will work as good or better than the Polaris oil.
I reccomend Castrol Syntec 5w50.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
