New Tires?
Old Apr 17, 2006 | 09:43 PM
mustang99's Avatar
Default New Tires?
I am looking to get new tires. my question is what will i loose if i go to a 20 inch rear tire oppose to the 22's that are on it now..........and would i have to drop 2 sizes in the front also thanks
mustang
Old Apr 17, 2006 | 09:57 PM
Backinthesaddleagain's Avatar
Default New Tires?
You will GAIN power......but you will lose ground clearance and a bit of traction advantage from larger tires. With a 2WD machine you do not need to change your fronts.....but it will handle differently. You'll probably just get used to it.
Old Apr 17, 2006 | 09:58 PM
BigDog800EFI's Avatar
Default New Tires?
You will lose topend but have a better holeshot. The front tires won't matter, except that the machine will be sitting lower in the back.
Old Apr 18, 2006 | 06:18 PM
mustang99's Avatar
Default New Tires?
Thanks for the info guys........just wanted to make sure b 4 i went and spent the money
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
