700 EFI fuel pump/ fuses
Old Apr 19, 2006 | 02:21 PM
shaq700's Avatar
Default 700 EFI fuel pump/ fuses
I have an 04.5 700 efi which is getting water up, in, around the fuses and ends up making the pump cut out. It went last Fri. on a run, had to get towed out, pump quit, the bike then sat in the garage all wknd until I tried it again Mon. night and it started right up....pump sounds strong!! Last night took the front end off to clean in that area, pump was still working at this point, pulled the fuses, and sprayed in there with compressed air.Now the pump won't work again!! Has to be electrical, somthing to do with that fuse pack?!
Any ideas....anyone
Old Apr 19, 2006 | 07:56 PM
floodrunner's Avatar
A good coat of dielectric grease on the spades of the fuses will greatly reduce their vulnerability to moisture, but it sounds like your problem is more than just a faulty connection with the fuse.
Old Apr 19, 2006 | 09:28 PM
lonnythepimp's Avatar
turns out it was only a corroded and loose connection about 8" from the pump itself, cleaned it, put in new grease and its good to go.
Old Apr 19, 2006 | 09:48 PM
Backinthesaddleagain's Avatar
It would appear that 'shaq700' has morphed into 'lonnythepimp'.
How about 'shaqthepimp' instead.....LOL
Glad to hear you got it squared away.
Old Apr 19, 2006 | 10:01 PM
One is my work computer and other is home computer...But I like the sound of "Shaq the Pimp", I think I found a new handle.
Hunter100us
Oct 7, 2015 11:46 PM
Jason Poulin
Sep 20, 2015 02:49 AM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
Jason Richards
Sep 4, 2015 06:17 PM
Unzzy66
Jul 11, 2015 10:01 PM
