sunpro tach 2stroke single cylinder
Old Apr 20, 2006 | 11:27 PM
drlang's Avatar
Default sunpro tach 2stroke single cylinder
Did I read that the sunpro tach can be used on a polaris 2stroke? Was it Bubba?
Old Apr 20, 2006 | 11:51 PM
Fastestdad's Avatar
I got one on my 97. Set it at 4 cyl. Works good .Got it at Oreilly auto parts.
Old Apr 21, 2006 | 10:38 AM
conig's Avatar
heres the instructions most use, I did when I had mine hooked up. makes sure you seal the tach up.(I didn;t write these)
was a SunTach I got from Autozone. There's not too much to the install but if interested how I did it, I found this post I did quite a while back. So ignore it if it bores you. So here it is.
The Tach is a Sun Supertach II which I purchased from Autozone for about $35. There's a black faced one that's the same for about $29. The choice is yours. You will also need to go to radio shack and pick up a pack of red wire splice/coneectors to connect the wires off the tach to the bike(it actually comes with 4 in the package but you actually need 5. You also need to pick up a pack of wire conectors(yellow I believe). I'm not sure what the proper name for these are. It's the type of connection that you use to join 2 wires together with a crimping tool. Both of these together probably won't cost you $3. While your at the shack, also pick up a tube of clear silicone with the long pointed end on it if you want to add some additional element protection to it.
#1. Remove the front cowling(hood) off of the bike and disconnect the battery cables in the back of the bike.
#2. Take the mount that comes with the tach and put it in a vice and smash the bottom of it till it's flat and not curved anymore(you'll see what I'm talking about when you look at the mount). Do not flatten out the concave part of the mount that the tach actually mounts on to. You need to flatten the bottom of the mounbt because you will be mounting it onto one of the bolts holding the handlebar in place. You will have to take a bolt off of the handlebar mount (one of them on the front side of the bike)and drill out the hole on the bottom of the tach mount big enough to slide the bolt through.
#3. Use the silicone and apply some all around the inside edge of the face of the tach and use a shop towel(or a rag with little grain to it) to force the silicone into the inside edges of the face. Do the same thing to the bottom side of the tach. Now make sure and slide the protective wire covering all the way up and into the tach housing and then slide the rubber grommet all the way up the wires till it is at the inside edge of the tach housing. Then take the wires and slide then through the tach mount and slide the plastis tach housing securing cap onto the wires all the way up to the tach and tighten the tach onto the mount.
#4. Use some more silicone to fill up the area around the wires coming out the back of the tach and let dry. Make SURE and put the switch on the back of the tach to the 4 cyl setting!
#5. Now mounthe tach by bolting it down onto the front side of the handlebar mount.
#6. Sit on the bike in your normal riding position and gently bend the tach towards the front of the bike until you are able to see it the way you want to.
#7. You will need wire cutters/strippers/crimping tool now. Connect the green wire to the Yellow/red wire coming off the rev limmiter switch located right behind the oil tank on the right side using the red splicing connectors that come with the tach.
#8. Connect the black wire to the brown wire coming off of the headlight wires(connect it as far down as you can so it won't be visible when you put the hood back on the bike).
#9. Connect the red wire to the Red/white(should be able to use the one off the ignition switch although I believe any Red/white would work) off the ignition switch.
#10. Take the wire cutters and cut off a 1' section off the white wire and take the 1' piece and cut it in half. Then twist the 2 pieces together and stick the end into the wire splicing connector and crimp it. Then taqke the white wire coming off the tach and put it into the other end of the crimp connector and crimp it together so that you now have 2 white wires, one of each to connect to the green wires coming from each headlight(that way your tach will be illuminated at night no matter whether you have the light on dim or bright)
#11. Here's a bit of advice: Before you snap the red connectors closed, Coonect the battery back and turn the ignition on and use a power probe to check and make sure that you indeed do have the tach properly grounded and to make sure that you have power to it when the ignition is on and no power to it when the ignition is off. I'm sure this is a cake walk for you as you are a electrical engineer as I think I remember. If everything checks out, turn the ignition switch on and the tach needle should jump to 0. Then fire the bike up and see if it works(it should).
Old Apr 21, 2006 | 10:03 PM
drlang's Avatar
Wow this way better than I had expected! Thanks, Doc
Old Apr 22, 2006 | 09:51 AM
16polaris's Avatar
Just make sure you keep your battery on the bike. I had mine removed and I fried 2 tachs before I realized what was going on.
Old Apr 22, 2006 | 10:04 AM
drlang's Avatar
I was wondering about that, what happens to the electrical system if I do a starter removal. I know by experience that if you run the thing with a dead battery all the lights blow out, what happens when you remove the battery?
Old Apr 22, 2006 | 01:48 PM
Whitedog's Avatar
the electrical system has to have somwhere for the extra "juice" to go, that the generator puts out. Like a battery, or a capacitor. I run the stock voltage regulator and a battery eliminator (capicitor). Two weeks ago my ground wire came off the capacitor, and burned up my tach. Now I have a brand new autometer! :-(
This time I put a 5 amp inline fuse in the hot wire to the tach.
Old Apr 22, 2006 | 04:55 PM
16polaris's Avatar
Hey Brent (Whitedog) I changed my email address to nauxier@foothills.net so send me your email addy again so I save it this time.
Dewhound
Apr 20, 2017 02:25 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
