Primary setup
Old Apr 21, 2006 | 10:10 PM
drlang's Avatar
Default Primary setup
Are the weights supposed to be in contact with the rollers with the engine off? They do make contact with the clutch bolt removed, but with the bolt in and tightened, the face moves in about an eighth of an inch.
Old Apr 24, 2006 | 11:18 AM
Speedwerx's Avatar
For your application it doesn't matter once you start you machien the weights will move and come in contact with the rollers.
Old Apr 24, 2006 | 06:54 PM
drlang's Avatar
Do you know what my application is? If you do you've been reading and paying attention, to which I say good job and thanks.
The machine is being setup for 300ft drags if that matters. Doc
Old Apr 24, 2006 | 07:18 PM
Speedwerx's Avatar
Still doesn't matter.
Old Apr 24, 2006 | 11:33 PM
drlang's Avatar
Now I've got to get rid of about an eighth of an inch of belt to sheave play. arghh
only supposed to have .020 and the belt measures good
Old Apr 25, 2006 | 10:32 AM
Speedwerx's Avatar
What did you change to cause this did you remove a washer from your primary?
Old Apr 25, 2006 | 07:50 PM
drlang's Avatar
No, I think it's just plain wore out. I never really paid attention to it before. Now I'm actually tying to get some performance out of it and finding out how out of whack things are. I'll be taking apart the other 250 I have and see if I can make some pieces parts and sense out of this mess. Gadzooks, going fast is a pain in the ****. I appreciate your time, Mr. werx
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
jbrewster94
Sep 23, 2015 04:16 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
WilliamBos
Sep 6, 2015 10:53 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
