400 scrambler reverse grinding
Old May 11, 2006 | 03:40 PM
scrammy326's Avatar
Default 400 scrambler reverse grinding
hey got a quick question for you polaris guys. I just bought a 2000 scrambler 400 and it drives fine and goes into reverse fine as well, but when it starts moving in reverse it grinds. The grinding almost feels like slipping. I bought a manual for it but it really sucks and doesnt tell me anything about the tranny. Any tips?
Old May 11, 2006 | 04:19 PM
Silversteinfan's Avatar
I'm assuming your holding the override button, right???
Old May 11, 2006 | 04:35 PM
conig's Avatar
check your fluid level also if its low it can make it grind.
Old May 11, 2006 | 08:06 PM
scrammy326's Avatar
I replaced the tranny fluid it came out looking good too. It grinds in reverse the same when i push the override button.
Old May 11, 2006 | 08:28 PM
JjEjFjf's Avatar
I have a 97 Sport 400L and the shifter fork is worn pretty bad and it allows the gear/dawgs to grind. A shifter fork for it cost around $120 not to mention about another $100 for the gears that are half worn out from the grinding.
You might want to check the linkage to make sure its allowing it to fully engage into gear.
I noticed it before i bought it , but like you i thought it was the belt slipping.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
r1pilot83
Sep 27, 2015 07:38 PM
exmotocrosser
Sep 26, 2015 08:18 AM
