Turbocharger? And trail boss price Question
Would a turbo from a Switchback be able to put on a sportsman or something i know the engines are different but i was curious......
Also i am selling a 1991 Trail boss w/ a pipe and almost new tires, scrammy lights and new seat cover was wondering what it would be worth? oh yeah....2x4 w/o low range
the short answer is yes. Technically you can bolt a turbo up to anything, and with a $20-$50 manual boost controller from ebay, you can even do so safely. What i do not know, however is if or not the FST sled's manifolds will fit the sportsman or not (doubt it)... What i'd do, is get some steel flex tubing and bend it around until you get a set up that actually works. Once you've got these manifolds set up, unbolt everything and take it to a local exhaust shop and have them bend a tube to match it. You could even get it ceramic coated. This may be fairly costly, but you can bet it would be cheaper than buying a turbo kit from anywhere else... good luck! [img]i/expressions/face-icon-small-smile.gif[/img]
toonces
Oct 16, 2019 12:11 PM
