does bigger=power
Old Jun 22, 2006 | 06:05 PM
ftwflh's Avatar
Default does bigger=power
Originally posted by: scramblered
it will not add power to the engine,but give more'usable' powerband at the trigger,polaris atvs' and sleds are generally geared too high for factory application,now if you want more low end,gear down a little,but
you'll need to follow close what the primary clutch is doing as to known what helix it should fit best in the secondary,it depend on engine compression and power and some others factor as altitude and air density.
make a black pencil mark on the primary sheaves til the very top to see what the system is at now,after a ride
(you must wide open throttle for a least 1/2 miles to fully close the sheaves)remove the clutch cover back
and you'll see what happen with the belt before going messed-up the gearing.
Some guy dont want get that deep into tuning a quad(unlike some of us[img]i/expressions/face-icon-small-wink.gif[/img])
But with the 330 Trailboss if you gear it down you will have no topend at all.Stock topend is only around 45mph due to the clutching.I have our 330 where it pull good and tops out around 55mph.
Old Jun 23, 2006 | 01:43 AM
TBJAY's Avatar
mine is sock right now and i hit 60 with mine on flat ground
my uncle was right next to me with his kodiak and a digital speedo
i cannt complain about the speed i just wanted more low end for mud and uphill trails
nothing to drastic
Old Jun 23, 2006 | 07:59 AM
ftwflh's Avatar
Try the pink spring
Old Jun 23, 2006 | 06:41 PM
TBJAY's Avatar
now when you sya the pink spring do i need the whole kit or just the pink spring?
this may be stupid questions but i am new to atv's so i apologize for my noobnis
Old Jun 23, 2006 | 11:12 PM
  #15
ftwflh's Avatar
Just a spring the part number is PATV8 list price is $17.95 add about $10 for shipping.
Old Jun 24, 2006 | 03:07 AM
  #16
TBJAY's Avatar
what site do i just get just the spring
Old Jun 24, 2006 | 10:03 AM
  #17
ftwflh's Avatar
www.erlandsonperformance.com
Old Jun 24, 2006 | 04:06 PM
  #18
TBJAY's Avatar
well i just ordered the pink spring
now does any boby have a write up on how to put it in?
Old Jun 25, 2006 | 04:20 PM
  #19
ftwflh's Avatar
Do a search in here for primary spring
If that doesnt turn up what you need when you get the spring we will post you diretions.
Old Jun 26, 2006 | 07:41 PM
  #20
TBJAY's Avatar
well i searched but could not find what i need
if someone could post the instructions that would be great
