does bigger=power
Old Jun 26, 2006 | 11:25 PM
  #21
ftwflh's Avatar
Default does bigger=power
First thing is 1.remove left footboard 2.remove belt cover and belt 3.stick a piece of wood in the front clutch to hold it 4. use a 5/8 socket to loosen the center bolt 5.use a 7/16 to take the 6 outer bolts out 6. take center bolt out 7. take notice of the X on the outer cover and spider(they have to be lined up to be in balance) you can mark the cover and spider with a marker to line it up too.
8. replace spring 9.start center bolt and line up X then start the 6 smaller bolts 10. torque the outer (small bolts to 18-20 ft lbs) the center is torqued to 40 ft lbs.11.replace belt and cover and footboard. 12. drink a beer then test ride[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 10, 2006 | 12:46 AM
  #22
TBJAY's Avatar
well i put the pink spring in and i climbs hills better which is good but i didnt hit any mud yet with it
the one that was in it is blue is that a good one for a 2006 trial blazer or is hat one blue too?
thanks for the instructions they were very helpful
Old Jul 10, 2006 | 08:08 AM
  #23
ftwflh's Avatar
The blue is stock in most
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
byronman
Sep 6, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
