Winch cable (wire to rope)
Old Jun 27, 2006 | 03:18 PM
Zbart1's Avatar
Default Winch cable (wire to rope)
Well PTOWO
Thanks for the input, As far as riding in a oven …….I have felt like it was some days ….but that’s another story!
The temperature problem comes from the drum on the winch conducting heat from the electric motor. On the truck winch’s it can burn your fingers. I guess they make heat shields for the first few wraps that are designed to help this problem.
Old Jun 27, 2006 | 11:08 PM
JCDEYO25's Avatar
When I redid my winch with the Amsteel I also replaced the roller fairlead with a hawse fairlead....You can get them in billet aluminum or uhmw....The rollers can pinch the rope if you're winching at angles where the rope is being wound in the corners of the fairlead........I'm not saying you can't use a roller but the hawse is suggested.....
John
Old Jun 27, 2006 | 11:16 PM
PolarisTheOnlyWayOut's Avatar
Well i guess the eletric motor does create some heat specially wen pulling yourself out of some sticky mud...another problem you won't have to worry about if you stick with the cable...
Old Jun 30, 2006 | 03:18 PM
Bradb21's Avatar
Originally posted by: Zbart1
Bradb21.................what size did you put on?
I got 50 feet of the 3/16" from Masterpull with the rock guard and the aluminum fairlead
Old Jun 30, 2006 | 03:28 PM
  #15
medic13's Avatar
don't forget about warn has a kit that has all the stuff.
toonces
Jul 31, 2015 09:27 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Bratman2
Jul 23, 2015 12:36 PM
cornermike
Jul 8, 2015 11:44 PM
