400 2 stroke bebuild?
shouldn't need a new rebuilt with 1300 miles on it,as said above,it depend what ratio those miles was put through,
normally i'll run the first 200 miles at 32:1 or 40:1 oil ratio,then check spark plug reading,,those engine run best around 42:1 tough...
Originally posted by: TBJAY
you put in the title that it is a 2 strokeif thats the case there is no oil to change.
clean the carb and it most likely needs new clutch buttons drive and driven and a belt change.
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
