Scrambler 2 speed tranny?
Hey guys I have been reading about the similarities of the Explorer 2 speed tranny and the scrambler. Would it be possible to bolt in a 2 speed into my scrambler? That is the one thing I have ways wished I had with this quad. I do alot of low speed crawling as well as high speed runs. Just curious if this would be an easy swap if I got a used one. Thanks!
It'll fit. Helped a buddy on his. Tranny bolts in. You'll need all shifting apparatus that comes with the 2 speed including the mounting bracket which needs to be relocated to the same dimensions where it came from. Also was able to heat and bend the shift lever to fit in the original opening. The quad works really nice.
exmotocrosser
09-13-2019 06:12 AM
