Understanding brake design
Old Jul 30, 2006 | 05:44 AM
thedoc's Avatar
Default Understanding brake design
as per my latest "dirty deeds" pictures below I have got my "rear brake" sort of working via the foot pedal
It started when I was fixing front end A Frames etc and I did a bit of work on front calipers to adjust etc, and I noticed the master cylinder has 3 pipes comin off and not just 2, ie to front only so then I saw the rear brake also has a hydraulic feed so the hand operated lever actually goes to all 3 brakes
so looking at the diag for rear brake it is both mechanical and hydraulic
but what I am not able to see without taking it all off is how do the 2 work together - like when I step on the foot pedal does that simply activate a fully mechanical link to the pads or does it do it via the hydraulic system [sort of like a secondary master cylinder] so as to feed back pressure to the front brakes??
I am thinking it is purely mechanical to back brake only but some of the design things I am seeing are rather ingenious so I am still wondering
Old Jul 30, 2006 | 06:05 AM
DAVEY300's Avatar
The foot pedal is mechanical it works off of 2 small dowl rods inside of the caliper,when you change the pads make sure you lube the dowl rods very good. hope this helps!
davey
Old Jul 30, 2006 | 09:53 AM
thedoc's Avatar
thanks for that, and as I expected
1/ hand lever goes to 2 x front brakes plus 1 x rear via hydraulics
2/ foot pedal only goes to rear via mechanical
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Sassinm1
Sep 30, 2015 04:23 AM
Sep 30, 2015 01:37 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
