scrammy making odd squeeking noises when trying to start, PLEASE HELP!!!
Old Aug 2, 2006 | 11:44 PM
bjrjr16's Avatar
Default scrammy making odd squeeking noises when trying to start, PLEASE HELP!!!
Yay, yet again another scrammy problem. its a 98 and the last time i will fix it. OKay it was down for a while due to a bad cdi. Put the new cdi on it and it started right up and everything was fantastic. I didnt ride it though because i wanted to make sure everything was a ok. I gave it a real good warm up then shut it off so I could check the plug for color. Whne I shut it off it made a weird noise like something was still spinning then it stopped. Now when I pulled it over it started making puffing noises as if it wanted to back fire, then I was hearing these odd squeeking noises, its very hard to tell where they are coming from with only one person trying to work on it. It does it if the ignition is on or off. I am thinking it could be something like a bearing?? It never locked up or anything and I didnt hear anything else while it was running. It sounds like it is coming from the left side of the engine maybe on the bottom. What are your suggestions on what it could be? Thanks alot, Brian
Old Aug 2, 2006 | 11:50 PM
2manytoys's Avatar
Maybe a head gasket or is the drain plug tight? If the plug is not tight it will leak compression and could squeak or the same with teh head gasket.
Old Aug 3, 2006 | 12:03 AM
bjrjr16's Avatar
Hey maybe, Never gave it a thought-I had both the base plug and head off while I was waiting for the cdi. Thanks, Will give her a try now, Brian
Old Aug 3, 2006 | 12:06 AM
crashby's Avatar
it could be the belt......
Old Aug 3, 2006 | 12:46 AM
bjrjr16's Avatar
It is happening when pulling it over. I tried starting it but it puffing and popping not backfiring though. So ive been screwing with it without trying to start it. But it sounds like metal grinding or something. It doesnt happen every single time I pull it over, just every couple of pulls. Thanks, Brian
Old Aug 3, 2006 | 01:49 AM
conig's Avatar
try taking the belt off and see what it does, if you here a puff it is proable the head gasket and your hearing leakage.
I tried a hotshot cdi and the timing was so out of wack I had to slowly pull the piston to the top of the stroke and then pull it or it would kick back and rip the cord back into the recoil. I also had the shut down issues.
I got a squeek like that from my bad crank bearing.
Old Aug 3, 2006 | 07:50 AM
thedoc's Avatar
for that sort of noise I would ask you
do you own a cat and has it sorta not been seen much of late
HINT - to confirm this is problem, wait 3 days and smell around the scrammy [with caution]
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
mpcop077
Jun 10, 2015 08:30 PM
winterwolf
ATC 3-Wheelers
Jun 3, 2015 07:34 PM
1000gade
May 27, 2015 12:37 PM
