Scrambler Rims
Old Aug 5, 2006 | 10:57 PM
XxScrammy500xX's Avatar
Default Scrambler Rims
i have a 2000 polaris scrambler and i dont know what type or rims i should get i want either chrome or black and resonably priced and if anyone has a set of used rims pm me thanks in advance
Old Aug 6, 2006 | 03:35 AM
scramblerXrated's Avatar
dont get anything less than douglas 190's... you might spring for some itp bajas.... the come in black or polished.
X
Old Aug 6, 2006 | 02:17 PM
thanks scramblerXrated for the reply and i noticed you had claws on the back of your scrammy and i have them 2 on my stock rims there 22-12-10 so would and of the .190 or baja wheels work with my claws thanks
Old Aug 6, 2006 | 03:13 PM
jayri's Avatar
I run ITP t-9's on my 400...same size and bolt pattern as the scrammy. I've got pics
Old Aug 6, 2006 | 08:33 PM
xxxscrammy....
as long as you get the same size rims that you already have they will werk great. the aluminum wheels will offer a considerable weight savings too!!
X
Old Aug 6, 2006 | 10:29 PM
Temper50's Avatar
Originally posted by: scramblerXrated
xxxscrammy....
...the aluminum wheels will offer a considerable weight savings too!!
X
I thought 2000 Scramblers already have factory alluminum rims, well mine does anyway, not sure if all of them did.
Old Aug 7, 2006 | 12:35 AM
there were limited editions that came out with aluminum rims. and also a few years that came out with pianted aluminum rims as well... but the vast majority of scrambler production rims were painted steel...
X
Old Aug 7, 2006 | 01:49 PM
conig's Avatar
my 2002 400 rims were aluminuim, but they have there fair share of bends from too low of tire pressure. if you keep pressure at 6-7psi they don;t seem to bend, you just need to glass bead/strip all the paint off.
Old Aug 7, 2006 | 05:57 PM
TruBlu02's Avatar
What size tire can you go up to on a scrambler? I have an 02 and I would like a little bigger tire I can take in the mud. Not to aggressive though.
Old Aug 7, 2006 | 07:17 PM
i have seen guys with 25's on theirs, but if you have 4x4 youll need that size if not 1 inch bigger up front. also with the bigger tires, youll have clearance issuses with the floorboards. so youll need to move them forward a bit.
X
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
