melted line under carb
Old Aug 16, 2006 | 03:32 PM
jclaude's Avatar
Default melted line under carb
I was doing some maint. on my bike and I noticed the little tube attatched to the carb under the fuel bowl was melted through from setting on the head. I'm assuming that it is just a drain tube. I cut off the melted peice and and replaced. My question is I cut off about 4 inches so it dosn't hang down as far as it did does this matter? Also would that have affected how the bike ran? I also noticed the seal between the filter housing and the big plactic nut that holds it all in place was riped and hanging. I found some dust in side the air box. I replaced the seal and wiped the air box clean. Has any one else had this problem.
Thanks in advace,
jclaude[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 16, 2006 | 04:57 PM
madmatt1971's Avatar
I'd suggest that you get a new peice of fuel rated hose and extend the tube to a at least the same location. If it were me I'd brint it down to the lower frame rail. It's a fule bowl overflow if your float sticks open or if you roll the bike. If that fule hits something hot enough you could have a fire between you legs. As for the seal I'm not sure since I don't ride that type of bike.
Cole Hadden
Jun 15, 2025 09:05 AM
GregM
Mar 6, 2018 06:53 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
