My worst nightmare!
if I remember right. The great honda's had a problem with the alternator not recharging on the forman 450's. Enough problems to have a recall and the part was back ordered for 3 months. so there gos the last reply out the window. If you let your quad sit you should get a (battery tender) it will trickle your battery slow while not in use and keep the battery active so when you do need it, its not sleeping
latter
bdscram1
99 sc 400 rcr ful-mod
rick ritter for pres
latter
bdscram1
#16
If it is gonna sit for a long time, use fuel stabilizer. Even with fresh fuel in the tank, the carb will still have old gas in it until it starts & runs a while.
Alternative method, shut off the gas about 50 feet from where you park it. Drive it to it's parking place & let it idle until it dies. You can put it in neutral & rev the engine a little to burn the gas in the carb quicker. Then when you add the fresh gas, it will mix with what's there. Now open the fuel valve & it should start right up.
My Polaris never sat over a month yet, but it sat clost to it a couple times & was slow to start. Once running, it was fine & re-started good.
I used to have a Honda that wouldn't start after sitting for a month unless I drained the carb & turned the gas back on. Didn't have to add fresh gas, just drain the carb...strange. Not a Polaris - only problem, but I think they a little worse at this than most.
#17
Hey settle down im just kiddin i dindnt mean to offend anyone. People take things way too seriosly these days. The new polaris's are cool but the older ones are junk i had one it averaged about $400 a month in repairs so i have my reasons to dislike polaris.
gogogo
Oct 15, 2015 05:40 PM
