Sputtering after washing
Old Sep 5, 2006 | 11:06 PM
flyinscrammy's Avatar
Default Sputtering after washing
Each time I wash my 05 Scrammy it sputters for quite a while after I wash it. At first I thought that it was from powerwashing it, then i thought it was getting the filter wet, now I don't know. I hand washed it and made suire the filter stayed dry. Any suggestions?
Old Sep 5, 2006 | 11:18 PM
jayri's Avatar
This has happened to me on my 700, because I sometimes take water in the exhaust pipe and it must run down the pipe to the motor.
Old Sep 5, 2006 | 11:19 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
After washing check it at night to see if there is any sparking on or around the wet wires....also water may be getting in the carb.....how long does it sputter for.....caper....
Old Sep 5, 2006 | 11:25 PM
But my pipe exits on the bottom... It's a thought though.
Old Sep 6, 2006 | 12:39 AM
scramblerXrated's Avatar
might check a few things.
make sure the sparkplug wire is secure and tight on the spk plug. check all your connections on your cdi box and voltage regulator. it could also sputter when the coil pack and the wires coming from it are wet.
X
Old Sep 6, 2006 | 01:53 AM
Briman's Avatar
What they said. You could also try spraying a fine mist silicone on your wiring, Brian
Old Sep 7, 2006 | 12:34 AM
Where is the CDI box? Voltage Regulator? I think I can find the coil pack, on second thought, where is the coil pack. 05 Scrammy 4X4. Thanks
Old Sep 8, 2006 | 10:24 AM
Towelie's Avatar
My motto is, "why wash it?" [img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 8, 2006 | 08:04 PM
Fenton88's Avatar
try checkin around the carb for a complete seal could get some moisture in there..just another thought
Old Sep 9, 2006 | 04:45 AM
thedoc's Avatar
you beat me to that one Towelie
however every time I leave mine at beach and return to Cairns [like this morning] I give it a very good hosing down to get all salt off but it always starts OK
ReconBayou
Oct 31, 2022 05:37 PM
ltrmc02
Aug 22, 2021 02:34 PM
Bernhard
Sep 25, 2015 12:45 PM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
