05 Scrambler bearing failure AGAIN!!!!!!!!
Old Oct 2, 2006 | 09:25 PM
biddog's Avatar
Default 05 Scrambler bearing failure AGAIN!!!!!!!!
i have had the same thing hapen to me i dont nrealy what its doing it but it was so bad it cracked my brake caliper and my axil was prity bad i dont no what did it but i had so mush play in the back that you code see it wen i went around a corner it was like 900$ to git all the stuff i had to redo the hole back
Old Nov 15, 2007 | 07:25 AM
blinim's Avatar
Hi Rick,
New to this forum (looks great, pity I'm in the UK - you US guys seem to have best country for quads).
Got 2005 Scrambler 500 H.O and have same probelem exactly as you describe with rear axle bearing.
Second one failed in 3 months with only 200 miles of on/off raod work (what it was designed for) in England and Wales hills.
Did you ever get to the bottom of the cause and sort a good solution - problem gone away?
Thanks.
Old Nov 15, 2007 | 09:07 PM
dirtsnow's Avatar
Yes I am wondering too, what caused it? I now have 300hrs on my scrammy & still have
not touched the bearings, I have been in mud, water, lots of sand & snow. the only thing
I have done back there is put a new chain & front sprocket on & new rear brake pads!!
Old Nov 16, 2007 | 05:05 AM
blinim's Avatar
Oh well, perhaps third time lucky.
Let you know what I find/what happens.
Snow! Not seen any of that over this side of the pond for years (lots of water and mud though!![img]i/expressions/face-icon-small-happy.gif[/img]).
You can see what we get up to on www.quaduk.net http://www.quaduk.net/viewtopic.php?t=285
Thanks.
Old Nov 16, 2007 | 03:44 PM
  #15
dealseaker's Avatar
I grease mine after each ride, some grease comes out the side, I just put a couple pumps in, I grease the ball joints and A arms to get the water out mostly after each ride as well as the swing arm bushings.
Old Nov 29, 2007 | 01:40 PM
  #16
blinim's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img]
OK guys, sorted the problem.
Wasn't bearing failure. What happened, and I did not notice it, was the collar on left of rear disc that pulls the bearing in to place, had loosened and unscrewed.
Simple when you know!
Thanks for all your input - Have fun! (Apparently we are getting snow this weekend - 2 inches and going next day - so much for UK winters - go and get very muddy anyway)
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
jbrewster94
Sep 23, 2015 04:16 PM
Nosparkpolaris
Sep 20, 2015 04:21 PM
