03 700 left cyl. plug?
I remove both side covers, you can access it from both sides but I break it loose then use a short piece of rubber fuel line pushed on the plug to remove and reinstall it from the left side. Blow out any dirt before you break them loose....
i used a 1/4 inch ratchet with a 3/8 adapter and a spark plug socket. it fits in there if you wiggle it just right. ive heard it was a pain, just takes the right stack of tools.
some sparkplug sockets are different lenghts, so it helps to have one or twelve to try.
good luck!
good luck!
