80W-90 gear oil - okay in trans?
Old Sep 27, 2006 | 08:39 AM
thedon's Avatar
Default 80W-90 gear oil - okay in trans?
It has new Polaris AGL fluid and was topped of with the Valvoline 80W-90 gear oil. Is this okay or should it be changed? From what I see everyone recomends bar and chain oil if the dealer is too far away?
Old Sep 27, 2006 | 09:42 AM
NBsportsman's Avatar
80W90 gear oil is not recommended for the transmission as it is too heavy as compared to the Polaris AGL. If you don't want to run the Polaris oil I would use a synthetic motor oil (5w50/0w40) instead of the gear oil...
Old Sep 27, 2006 | 01:58 PM
tmorris1's Avatar
I think people have used chaincase oil, not bar and chain oil. Definitely don't use Bar and Chain oil it is just crap oil and not meant for a tranny. Why did you top it off, is it leaking, or did you just run low on the AGL.
Old Sep 27, 2006 | 06:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i wouldnt recommend mixing differnt weight oils in anything unless you have too. 80-90 is only fo rthe rear end.
Old Sep 27, 2006 | 06:58 PM
trooperK's Avatar
The Valvoline is too viscous and you should never mix synthetics with regular lubes. The AGL synthetic should be used in both the trans and the rear dif. 80w/90 is too viscous for the rear dif also.
Old Sep 27, 2006 | 07:44 PM
Boomer2's Avatar
Amsoil makes a oil for Polaris Transmisions. Here is a link to there site Chaincase Oil
Old Sep 27, 2006 | 10:30 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
unless its changed in 2 yrs between your 04 and my 06 the book says to use 80-90 gear oil if you dont have the synthetic oil for the rear end.
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
