VIN on a Magnum
On a 98 Magnum, the VIN number is etched into the frame on the left side between the a arm and the oil tank mounting bolts. Take a rag and spray WD 40 on it and wipe the frame clean. You should then see the VIN number etched into the frame. Mine also has a sticker under the top headlight that has it on. Hope this helps.
09-09-2015 06:57 AM
