no power with key 2002 500 scrambler
Old Oct 26, 2006 | 12:47 AM
dirtsnow's Avatar
Default no power with key 2002 500 scrambler
Originally posted by: BassBlaster
I had the same problem just the other day....it was a loose battery connection.
I will check mine to make sure they are clean & tight. thanx!!
Old Oct 26, 2006 | 07:40 PM
mudrun's Avatar
I put all the plastic on, took the machine out for a hard ride jumps, mud, rain all on the same day. everything is fine, I didn't take the switch apart, I just worked it back and fourth. I don't use the switch to shut off my machine can't remember if I hit it the day it died. But I will keep this in mind. Try to find out if there is a jumper to bypass this if it happenes again.
Old Oct 27, 2006 | 06:45 PM
dirtsnow's Avatar
ya thats the thing, I am moving mine back & forth now & then & the problem
seems to go away now. I think if the kill switch stays still to long it looses
contact. I was never using mine before either. thanx!
scram5050
Aug 30, 2024 01:39 PM
maxjung
Jul 13, 2015 05:11 PM
Chocobamofo
Jul 10, 2015 07:46 PM
cSchwartz
Jul 9, 2015 02:43 PM
MNatv89
Jul 7, 2015 11:36 AM
