How do you remove the pull start?
Old Oct 4, 2006 | 11:13 PM
ecordeddie's Avatar
Default How do you remove the pull start?
The pull start recoil won't recoil the rope anymore....dang it all!
I've got a '93 350 4x4. I've got all the brackets off and the drive chain removed....but how do you get the recoil pulley off?
Thanks,
Old Oct 5, 2006 | 05:53 AM
Instigater's Avatar
They have aligning pins that sometimes corrode and "freeze up". LIGHTLY tapping on the housing while pulling on it should do it. You could use a screw driver to stick in the rope hole and LIGHTLY pull outward. This and tapping should do the trick! Once off, hit the pins with a wire brush. Just use RTV on the sealing surface when putting it back on.
Old Oct 5, 2006 | 08:33 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like you broke your spring. just becare prying on it, not to break the housing.
Old Oct 5, 2006 | 10:19 AM
ecordeddie's Avatar
I bought this thing used and never tried the pull start until recently...and you know what... I think the whole damn spring was missing in the first place. I have the pull start housing off, I can see the wind pulley, but I don't see anything that looks like a spring. I should be able to see it right?
Dammar
Nov 14, 2015 07:41 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
momofo
May 27, 2015 12:06 PM
PLEA$URE
8
Jan 31, 2000 10:55 PM
