Found a way to make the Hawkeye rear-end softer
Old Oct 7, 2006 | 07:03 PM
sheepdogMSP8117's Avatar
Default Found a way to make the Hawkeye rear-end softer
There was squeaking coming from the rear end on even the smallest bump, so I greased both fittings and sprayed GM PTFE SuperLube on all the pivot points/ bushings, then worked it all in by pushing the rear end up and down several times as far as I could.
The squeaks are gone and the rear end is very smooth. Prior to that the rear end was very stiff, now it's only moderately stiff.
Hope this helps!
Geolorgist
Jul 26, 2015 09:48 AM
Captjay
Jul 23, 2015 12:33 PM
95wolv
Jul 17, 2015 08:13 PM
Shifts
14
Jul 13, 2015 08:41 AM
Unzzy66
Jul 11, 2015 10:01 PM
