scambler Oil
Old Oct 8, 2006 | 08:23 PM
marksduramax's Avatar
Default scambler Oil
I got a 99 scambler 500 4x4 HO going to do a Oil chage on it for the frist time Had dealer do it last year... I got 2 qts of oil and a oil filter... Where is the oil plug drain plug at
Old Oct 8, 2006 | 09:26 PM
dirtsnow's Avatar
one is at the bottom of the side oil tank where u check the oil (left side of
the bike) this is where most of the oil is at. The other is under the skid plate
on the bottom of the motor, this is what drains the rest of the crank case, a
much smaller amount is in there. This is because the scrammy has what is
called a dry sump oil system. U should drain both to get all the oil out.
Old Oct 9, 2006 | 12:10 AM
Ok thanks for the info also is 2 qts enough oil ?
Old Oct 9, 2006 | 04:41 PM
dirtsnow's Avatar
yes 2 qts. with the filter is good.
Old Oct 9, 2006 | 09:49 PM
Ok thanks for your help got it done to day thanks again
heywouldublowme
Aug 14, 2004 09:24 PM
DaSandBomb
May 31, 2004 07:46 PM
coolintheice
Feb 6, 2004 11:12 AM
Schweitzer
Jun 29, 2003 06:26 PM
