2001 4x4, how does it work?
Old Oct 9, 2006 | 09:58 PM
01xped's Avatar
Default 2001 4x4, how does it work?
I have an 01 325 Xpedition.
One front wheel will engage when in 4x4 and the other will not, the axle spins all the way to the axle nut.
I took it apart and found a wire leading down the strut to somewhere and I also found that the roll cage had a groove worn into it and that the plate behind it was bent and worn as well.
My question is: If I replace the worn components, will it work or is there some king of electrical problem?
Thank You,
Daniel
Old Oct 9, 2006 | 10:24 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it sounds electrical ,but i would still replace the worn parts if there bad b4 they break and you get stranded somewhere or has no damage. just a guess though.
Old Oct 11, 2006 | 03:45 AM
mrtwostroke's Avatar
a groove wore in the hardened steel ring inside the hub housing wow i've never seen that happened must have ran out of oil. the other peice you are refering to is the armature plate. replace it two. and check for a broken wire going down to the strut
Old Oct 12, 2006 | 11:21 AM
sonOFoldmanmoses's Avatar
hey i am very educated with 2001 AWD systems. Please PM me your number and i will tell you the right things to do.
Thanks, Josh
Old Oct 29, 2006 | 08:38 PM
TWM111261's Avatar
I hope you may be able to help me if you are good with the AWD system.
I have a 2001 scrambler AWD that has been acting up or about 6 months.
It some times will stall as soon as put in reverse if the reverse over ride
switch is not pushed. The 4wd does not work also.When I first bought the
machine new it had the same problem and the dealer replaced some switch
and had no problems for 5 years.
I took the switch off the transmission, checked the conector for corrision and
sprayed contact cleaner in the switch assy itself but same problem.
Do you know if this is the switch that causes this problem ?
Thanks for you help !!!
Tom
Old Nov 4, 2006 | 05:27 PM
caver101's Avatar
I have about the same problem with a 98 Sportsman 500. The front left will work on occasion. The right has not worked since I bought it (used). When I press the 4x4 button it lights up like it is in 4x4, but most of the time the front end does not pull.
answers??
Old Jun 2, 2007 | 05:17 PM
chiefjude's Avatar
I am now having the same problem that w/ my 2001 AWD Scrambler 500.
It just started doing it. It backfires loudly and starts to die, and has no power.
Is there a quick fix?
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
Ramman1
Jun 16, 2016 09:07 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
