4x4 did not work
Old Oct 10, 2006 | 10:15 PM
JimMQ's Avatar
Default 4x4 did not work
I have an 01 magnum 325. The 4 wheel drive did not work. I noticed the light was not lit on the AWD switch. After about 5 min of use it started to work.Has any one had this problem? Where do I start to check next time it acts up?
Old Oct 10, 2006 | 10:19 PM
x_scrambler3's Avatar
Is the Battary good in it? You need a good battery for the awd to work. You need to give us more info to help you figure it out.
Old Oct 10, 2006 | 10:23 PM
la90043's Avatar
seems maybe you might have a faultry electrial connection somewhere.............start giggling electrical wires................and switches
Old Oct 11, 2006 | 03:23 AM
mrtwostroke's Avatar
components in 4wd system consist of
electromagnetic coils in the front hub/strut
your switch
reverse speed limiter
reverse speed limit overide
battery could be the problem but if your awd light is intermitant that is a good place to start at the switch
Old Oct 11, 2006 | 10:31 PM
JimMQ's Avatar
The battery is good. I wiggled the wires at the switch and checked the connections at the trans. I diddnt check if the rev limiter was working with the button out. Is there any thing I should check?? Thanks for the replys.
Old Oct 12, 2006 | 12:48 AM
the usual prob with the reverse speed limter is it can get stuck on in any gear and you have to ride home. with the overide button in. but i would eliminate that anyway.
Old Oct 12, 2006 | 09:54 AM
sonOFoldmanmoses's Avatar
hey JimMQ PM me your number and we will locate your problem quicker than u can say AWD problem haha
Josh
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
