Tip: DIY Clutch Puller
Old Oct 12, 2006 | 01:17 AM
ndnflyr67's Avatar
Default Tip: DIY Clutch Puller
For all you guys and ladies who are to cheap to buy a clutch removal tool, or should I say frugal. You can easily and cheaply make your own. Go to your local Ace Hardare store and buy 9" peice of 3/4" ready rod with 2 nuts to fit the same. (Use Fine Thread) Take the 2 nuts and tighten against each other on one end and you are ready to pull your clutch. It is a bit long winded because it is threaded all the way but it works great. I have used it on all of my Polaris quads.
All you are doing is making a long bolt that will bottom out on the crankshaft. The 2 nuts tightened against each other on one end become the bolt head so you can put a wrench on it. The clutch is threaded on the inside. Once you have screwed it in til it bottoms out, it will take about an 1/8 turn and the clutch pops off. Of course if you can find a 9" long fine thread 3/4 inch bolt you do not have to go to all the trouble of making your own!
I hope this clarifys things abit
Old Oct 14, 2006 | 03:28 PM
SCRAMMYTODD's Avatar
I just wait till winter, put the bike on it side and pour water into the center of the clutch and thread a bolt into the clutch, push the bike outside, have a beer or two and walk out to find the clutch on the ground lol. Hope i never need to pull the clutch in the summer lol
Old Oct 14, 2006 | 08:16 PM
ndnflyr67's Avatar
WOW! Never thought of that. I wonder what else I can use that one on?
Old Oct 14, 2006 | 11:43 PM
BryceGTX's Avatar
ROG.. I like the beer part [img]i/expressions/face-icon-small-smile.gif[/img] Got any ideas about tightening the chain??
Old Oct 15, 2006 | 06:17 PM
Instigater's Avatar
Well, I can say that I just did hat you said about 3/4" rod. No good, It goes about one thread then locks up. The pitch is obviously different when I investigated the situation! Any other ideas? I didn't see any 3/4" fine thread!
Old Oct 15, 2006 | 06:28 PM
lslubecki's Avatar
Yes. 3/4 fine thread.
Steve
Old Oct 15, 2006 | 06:34 PM
Instigater's Avatar
No problem, That is why they make receipts! THANKS!!!
Old Oct 15, 2006 | 07:04 PM
Instigater's Avatar
I should have known, I've never seen a puller use coarse threads!
Old Oct 15, 2006 | 11:52 PM
ndnflyr67's Avatar
Woops! Sorry I should have stated in my original post to use fine thread. It was all that was available at my local Ace Hardware so go figure. I guess I owe you one and probably a few others also.
Old Oct 16, 2006 | 03:06 PM
Instigater's Avatar
Got my fine thread. I'll be swaping clutches when I get home! Don't worry about the whoops! Not a big deal!
