Tip: DIY Clutch Puller
Old Sep 5, 2009 | 06:19 PM
  #21
cbrf1wr's Avatar
3/4 inch fine thread trailer ball with a long shale and a large bolt or socket extension will work if you can;t find the fine thread.
Not all Hitch ***** are fine thread, but if you look around for a long shale one they usually are fine thread.
This is the ticket for clutch removal. It took a while to find this thread so I am going to bump it back up to the top so the next guy doesn't have to look as hard for it as I did.
Keywords: Drive Clutch Removal puller tool.
Old Sep 5, 2009 | 10:43 PM
  #22
rkuhnjr's Avatar
What are you pushing the bolt against?
Is it just a housing that can take that pressure?
And is there some reason you would want to pull your clutch often?
I need to put on lighter clutch weights after I jet my scrambler for 9k ft so this will save me some cash!
Thanks
Old Sep 6, 2009 | 09:13 AM
  #23
cbrf1wr's Avatar
You are pushing against the crankshaft. The clutch is bound to the tapered part of the crankshaft. Just make sure the bolt you use to push with is larger than the bolt that secures the clutch to the crankshaft and put the bolt head or 3/8 extension against the crankshaft and turn the hitch ball in to the clutch. When it binds get it good and tight and tap it with a hammer. Somethings got to give and the clutch pops right off.
Old Jul 5, 2010 | 02:23 PM
  #24
dingo2010's Avatar
Does this work for the secondary clutch too? I am trying a hitch ball, but it will not thread in. I also bought a 3/4 inch bolt, but it is too small of a diameter. The hitch ball is larger than 3/4.
Old Jul 5, 2010 | 02:44 PM
  #25
Speeddrive1's Avatar
I don't believe you need a puller for the secondary cause it is a splined shaft. Just pull the bolt and the secondary should slide right off.
Old Jul 5, 2010 | 07:26 PM
  #26
dingo2010's Avatar
It appears to be rusted on. When I removed the center bolt, it was rusty. I sprayed Liquid Wrench inside the hole and let it soak, but it will not budge.
Old Jul 5, 2010 | 08:29 PM
  #27
dingo2010's Avatar
This is on a 2000 Scrambler 2X4. Is the 3/4 inch size for the primary and would a 1 inch be needed for the secondary?
Old Jul 7, 2010 | 07:33 PM
  #28
dingo2010's Avatar
I don't get it. I have tried a 3/4 inch, a 7/8 inch and a 1 inch bolt and none of them fit. They are all fine thread. The 1 inch is closest in size, but it will not thread in even though the clutch appears to be fine thread too.
I was going to try coarse thread and metric, but cannot find either bolt locally.
Any thoughts on how to remove this secondary clutch?
Old Jul 9, 2010 | 08:01 PM
  #29
09 popo HO's Avatar
This video series will explain everything.
YouTube - Polaris Sportsman EPI Clutch Kit Install - Part 1 of 4
Cheers.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
