Getting Shocked Thru Grips On 2005 SP 400's
Old Oct 27, 2006 | 02:05 PM
oldsmoboat's Avatar
Default Getting Shocked Thru Grips On 2005 SP 400's
Both mine and my wife's are doing this.
No electrical systems mods.
My wife's has the "Polaris" Warn winch and mine has the Gorilla. I installed them both.
Mine started doing it before the install and hers never did it till last weekend.
Weird thing is, both have never done it anywhere but the desert north of Reno.
Any ideas?
Old Oct 27, 2006 | 03:26 PM
WAATV's Avatar
Described "shocked". Normally a human can't feel a 12 volt DC potential, which is all you're getting from the battery. The only place I can think of that has higher potential is the ignition system.
Old Oct 27, 2006 | 06:20 PM
oldsmoboat's Avatar
It's strong enough so that you can definitely feel it. Mostly the right palm and throttle finger though occasionally the left palm.
Old Oct 27, 2006 | 06:52 PM
WAATV's Avatar
Weird. 12 volts DC isn't enough to shock someone. To test, try touching both posts on your battery with your fingers - you won't feel any current (usually, unless you have an open wound or your hands are covered in salt water or something).
Besides that, nothing you are touching should be "live". Rubber grips, right? Or is this when you touch the handlebars directly?
And it comes and goes with your **location**?!? As in, geography affects it?
Old Oct 27, 2006 | 07:35 PM
TennesseeTider's Avatar
dry desert air = static electricity just like in the winter you get shocked more by carpet, cars, etc when the heat is on
Old Oct 27, 2006 | 07:52 PM
WAATV's Avatar
Oh, if it's just a momentary sensation then I agree - it's probably static.
I was presuming he meant a continuous sensation like a normal "electric shock".
Old Oct 29, 2006 | 04:07 PM
oldsmoboat's Avatar
It happens every couple of minutes, it's not a constant shock.
never even thought of static electricity being the cause.
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
bigred20653
Sep 19, 2015 02:11 PM
Brandon400
Sep 5, 2015 08:44 PM
