1997 scrambler 400L secondary clutch
I removed the primary and the secondary requires another size puller, the thread size is not 3/4 it is larger, any suggestions other than buying tool and when going back together any tricks with drive and driven clutch installation.
The secondary clutch shouldnt need a puller unless it is rusted to the shaft.Try spraying penitrating oil in the bolt hole and behind it and see if that helps.If it doesnt you will have to get a secondary puller.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
cdstang
Aug 31, 2015 07:52 AM
