Scrambler 500 gear reduction
Old Nov 14, 2006 | 09:36 PM
xler8ion's Avatar
Default Scrambler 500 gear reduction
You can copy that title topic I posted right into the search window and it will take you right to that discussion The last reply was on September 18, 2006.
Old Nov 14, 2006 | 10:02 PM
diryJ's Avatar
Originally posted by: lslubecki
Get a '99 polaris explorer 400 trans. It has low and high gear. It is a bolt in except you need to modify the shifter. Do a search. It has been discussed before.
Steve
Why did you say an 99. on that other thread it says to use 01 or 02 trannys
Old Nov 14, 2006 | 10:23 PM
lslubecki's Avatar
I was under the impression that the '99 was the last year for the explorer with chain rear and shaft front drive. Maybe I was wrong.
Steve
Old Sep 22, 2014 | 11:28 PM
smbony9's Avatar
Default tran swap
I dont know where everyone finding these chain rear shaft front xplorers at they didnt make one they are chain front and back you can even look up on polaris website manuals
Old Sep 23, 2014 | 05:15 AM
  #15
Old posts.. Explorer 400s from 95-98 were chain driven front and rear. The last year model 99 Explorer 400 had a chain rear drive and a front differential to the drive shafts instead of using a chain.Look at this link.Dirt Cheap Yamaha, Honda & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Sep 23, 2014 | 09:04 AM
  #16
TLC's Avatar
TLC
Pointless to lift kit a atv without IRS,
The only way to get more ground clearance on a SRA under the rear chain sprocket or rear diff which are the lowest points of the machine is to put on larger tires.
The easiest way to gear reduce a chain drive is to just change the tooth count of the sprockets. Larger back sprocket or smaller front sprocket.
scram5050
Aug 19, 2015 02:19 AM
mitchxc700
Aug 10, 2015 09:26 PM
1000gade
Aug 9, 2015 03:34 PM
djoshuah
Aug 5, 2015 10:59 AM
maxjung
Jul 13, 2015 05:11 PM
