400 Scrambler X upgrades
Old Nov 30, 2006 | 12:19 PM
conig's Avatar
Default 400 Scrambler X upgrades
rick is an authorized hpd dealer and can get you all there stuff at the same price. =)
Old Nov 30, 2006 | 06:23 PM
450trailrider's Avatar
I talked with rick about the Hpd pipe. I am planning on going through him no matter what I do.
Thanks for the info guys.
Old Dec 1, 2006 | 08:25 AM
jim's Avatar
jim
You can get your head machined but just keep in mind, HPD sells a cool head w/ added water passages for added cooling which I took advantage of since I planned on removing the fan from the front for weight savings & no problems w/ over heating. I didn't see a Wiesco pison on your list which should be added when bumping the compression stock is fine for stock but above stock should be changed. Not sure exactly the diff is in rpm between race pipe & trail pipe but the race pipe lets the engine really open up & rev higher & everything else the same, there is a big difference in performance from trail pipe & race pipe w/ appropriate clutching, I used both & prefer the race pipe. You can putt all day in the yard w/ the kids & then open it up when you want. No plug fouling or anything.
Jim
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
