No synthetic oil?
I found this in the Jiffy Ice Auger FAQ. I wonder why you can't use a synthetic oil in their augers. Does it actually provide less lubrication?
"What kind of oil should be used to make a Jiffy fuel mixture? Use only quality two-cycle oil to mix with clean fresh gasoline for fuel. A quality two-cycle snowmobile oil works well.
Do NOT use synthetic oils of any kind, they will void the warranty."
http://www.jiffy-on-ice.com/faq.htm
The reason is becase some synthetics are not to be mixed with fuels,They are ok for injected sytems ,All reguler 2 stroke oils can be mixed with fuels with no problem,so other than listing the types of oil you can /cant use they just tell you to run regular 2 stroke oil.
Yes synthetics are a far better oil,
Technical and How-To Articles
Aug 21, 2015 09:31 AM
