1997 Trailbazer Brake Question
Old Jan 4, 2007 | 11:15 AM
mtnxtreme800's Avatar
Default 1997 Trailbazer Brake Question
Just got a 97 Traiblazer, the foot brake set-up is disconnected and they bolted a flat piece of aluminum over the end where the brake arm used to be, the brakes work fine otherwise, was this a common mod, were these foot brakes a problem and commonly disconnected, or did the previous owner just butcher it for some reason, is it worth hunting down the pieces and reconnecting it???
Old Jan 4, 2007 | 03:12 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
they were really only a back up brake system that half the time it didnt work w/out braking your foot to use it.
Old Jan 4, 2007 | 07:36 PM
godIlove2ride's Avatar
The backup brake also only operated the back brakes and was just a backup. The brake lever on your bars operates both brakes and they work through a proportioning valve to govern the braking between front and rear.
toonces
Oct 16, 2019 12:11 PM
Stirling
Aug 9, 2015 01:49 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
DeFox500
Jul 26, 2015 06:32 PM
