Scrambler wheel/tire question
Old Jan 10, 2007 | 07:28 PM
Lukester's Avatar
Default Scrambler wheel/tire question
I have ITP C Series Type 4 Mud Lites, F- 25x8x12, R- 25x10x12 on my 03 Trail Boss (click my camera to see).
Can I put these on an 06 or 07 stock Scrambler? And what can I expect from perfomance? Pro's and Con's too please?
Thank you
Old Jan 11, 2007 | 10:23 AM
rundrave's Avatar
I beleive they should fit, bolt pattern should be the same 4/156 in the front and 4/4 in the back.
Not sure why you would want to do it. Those size of tires are going to really put a dent in performance. But if you do alot of mudding then more power to you.
have fun!
Old Jan 11, 2007 | 06:52 PM
ftwflh's Avatar
You need to keep the gear ratio the same as stock for the 4x4 to work right.
Old Jan 11, 2007 | 07:13 PM
Lukester's Avatar
ftwflh,
Are you saying that 25's all the way around will change that?
Old Jan 11, 2007 | 07:29 PM
ftwflh's Avatar
exactly.You need to keep the 1in dif in the fronts from the rear.
Old Jan 11, 2007 | 07:42 PM
Lukester's Avatar
OK, got it. Thank's again for the info..
fordfaithful21
Dec 7, 2015 05:52 PM
MooseHenden
Sep 6, 2015 04:24 PM
Logan Collins
Sep 5, 2015 08:03 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
DeFox500
Jul 26, 2015 06:32 PM
