valve adjust. specs
Old Jan 12, 2007 | 05:15 PM
rockinrodtex's Avatar
Default valve adjust. specs
i have a 03 polaris ranger 4x4 cant get it to start. i cleaned the carb, air filter ok, plug good, fuses good, spark is good. my compression is 45psi. not sure what it 's supposed to be. can you gain higher compression by adjusting valves to correct spec
Old Jan 12, 2007 | 05:39 PM
furnaceman's Avatar
should be about 100- 115psi sounds like the engine is your problem.
Old Jan 12, 2007 | 05:41 PM
cornbread2's Avatar
If the valves are tight it will lose compression. Check them.
Old Jan 12, 2007 | 06:59 PM
ftwflh's Avatar
If it is a 500 set both valves at .006 I am not sure on the 700s.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
