Crankshaft bearing replacement ? 400 sport
Old Jan 15, 2007 | 08:52 PM
SherpaT350's Avatar
Default Crankshaft bearing replacement ? 400 sport
When I replace the crankshaft bearings in my 400 sport , do I put the bearings on the crankshaft or in the cases ? Just wondering which is the easiest and least likely to break anything.
Thanks,
D.
Old Jan 15, 2007 | 10:06 PM
BGRDTRUK's Avatar
You want to put them on the crank shaft......heat them with a propane torch for a few minutes but don't get them to hot (to hot and it will turn blue) look for a hint of smoke from the oil residue from the factory (REMEMBER A BLUE COLOR IS BAD!!!!!!!!!!!) then with a screw driver pick it up and slide it on the cold crank it will fall right into place.
Let it cool for a couple hours and install case's on the crank.
Hope this helps.
Ean
Dec 19, 2022 08:48 AM
Peter_
Jul 18, 2015 07:06 AM
joeyupton
Jul 14, 2015 11:51 AM
clsharky
Jul 13, 2015 02:07 PM
John Boy
Jul 13, 2015 11:16 AM
