2001 polaris scrambler electrical problems
I have a 2001 scrambler and it wont charge my battery. i have bought a new battery and it will work for a couple of days and then it dies. dose anyone know how these batteries get charged? what is the part called?
thanks
thanks
The battery is charged by charge coils around the flywheel. They can be tested with an ohm meter. The power from the charge coils go to the voltage regulator, then to the battery.
Get your battry up to full charge(12.5 volts+)put a volt meter across the battry.Start motor you should go up to 14 volts or better.If not you have either a stator problem or voltage regulator problem.
skittero
35
Mar 1, 2019 12:39 AM
Big600twin
14
Jun 16, 2015 09:30 AM
hoopduerr
Jun 1, 2015 08:22 PM
