Bone Head Move
Old Jan 28, 2007 | 11:26 AM
  #31
trailbound's Avatar
Default Bone Head Move
The crank is supported by big ball bearings and the connecting rod on the crank has roller bearings.
Old Jan 28, 2007 | 11:32 AM
  #32
stendori's Avatar
Super Quad Patrol
I'm watching you!
soare you saying that the lack of oil in the engine wont hurt these parts?
Old Jan 28, 2007 | 02:23 PM
  #33
trailbound's Avatar
Not saying that stendori, but in my experience, I have not seen many cranks on 500s go bad. It is usually the cam which gets rounded off and the rings and cylinder go bad. If it a roller crank, its similar to a two stroke with just oil injection and mix. As long as the cooloing system was working properly, I would think the residual oil would have lubricated these enough while the ring tolerence between the dry rings would have seized. Just my two cents.
Old Jan 28, 2007 | 02:28 PM
  #34
stendori's Avatar
Super Quad Patrol
I'm watching you!
you may be right trail, but i would think it all depended on how long it went w/out oil. my point is only is there really any way of telling how much damage there actually is w/out completely tearing all down and inspecting all lubed parts? its a hard call for sure.
Old Jan 28, 2007 | 02:33 PM
  #35
trailbound's Avatar
I completly agree with you, but I can't help but wish for the situation to be an easy fix. I know what its like to have to pull one of these motors out of the frame and rebuild it yourself. It's alot of work, and I wish the best for the situation.
If I'm going to be on here saying stuff, I hope its stuff that will help people along the way as your words have helped me.
Every little bit helps.
Old Jan 28, 2007 | 03:57 PM
  #36
onesavage's Avatar
well spoken
Old Dec 28, 2007 | 11:37 PM
  #37
egressman's Avatar
Old Dec 29, 2007 | 12:03 AM
  #38
RickRitter's Avatar
I don't know if it is hurt to bad at all . I would not be suprised if the rings are stuck and compression dropped and the compression loss made it quit . I am not to worried about the bottom end , my concerns are with wiping out the cam journals and cam and rockers as well as the small end of the rod . Only was to know for sure is to take it apart .
That being said , I think the deal your dealer offered you is not to bad . Maybe negotiatte with him a little .
Rick
Old Dec 29, 2007 | 12:19 AM
  #39
so2315's Avatar
Why did we resurrect a 12 month old thread?
Old Dec 29, 2007 | 03:55 AM
  #40
New Rookie's Avatar
Who rode it without checking the gas and oil. I learned.... this is done before every ride.
