Trialboss 250
Old Jan 31, 2007 | 12:03 AM
310's Avatar
310
Default Trialboss 250
I have a 1986 polaris trailboss 250 4x4. I have had problems with it running. Every time i give it full throttle it bogs down and dies. I havent done any mods or things like that. It was running fine befor and now it wont run properly. THANKS for the help. P.S. i already cleaned the carb more then once.
Old Jan 31, 2007 | 12:29 AM
jta4455's Avatar
Have you checked the spark plug. Also what is the temp you are running at because a 2 stroke requires a jet change from winter to summer and vise versa.
Old Jan 31, 2007 | 12:36 AM
310's Avatar
310
The plug has been replaced and the gap is fine on it. I did not know about the whole change my jetting for winter. It is currently about -8.
Old Jan 31, 2007 | 01:44 PM
310's Avatar
310
bump
Old Jan 31, 2007 | 02:23 PM
xler8ion's Avatar
Since you have cleaned the carb and checked the float level, choke plunger and feel confident about that portion these are what I would suggest checking next....Fuel filter, make sure your fuel valve is on (turn it to reserve to test it and see if it makes a difference) fuel pump and pickup in the tank. Next if you have not solved the problem I would check the clutches..I had a secondary spring break and it acted like a fuel problem because it open and bog it at full throttle. Last is electrical..on mine I had a problem with the reverse override button being tempermental and causing a problem..I sprayed it with wd-40 pushed it a bunch of times and have not had the prob since. Let us know what you find.
Old Jan 31, 2007 | 02:30 PM
kickass210's Avatar
maybe it needs a top end rebuild, when was the last time u did one?
Old Jan 31, 2007 | 03:24 PM
310's Avatar
310
It still has its original top end in it. I think it might be the pilot jet is to big.
Old Jan 31, 2007 | 04:58 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
pilot jets only are made to work from idle up to 1/4 throttle. if it is dieing when you hold it open then its nto the clutches as the problem.is the plug wet after you kill it w/ full throttle or some what dry.too much gas, too little?
Old Jan 31, 2007 | 07:21 PM
310's Avatar
310
Well the plug did kinda seem dry now that you say so. So i then need to go richer on the pilot and lower the needle.
Old Jan 31, 2007 | 07:46 PM
jta4455's Avatar
If it ran fine before there is something wrong with it and can be fixed, if you lower the needle you are going to lean it out more and you don't want to do that. When you lower the e clip it will make it richer. What happens when you pull the choke when it is running? Or even try spraying carb cleaner in the intake to see what happens. Also you cannot rule out a crank seal, seen alot of em go out of the magneto side. Does it maybe seem like an elect issue, if so check the plug cap for resistance should be 5k ohms. If it seems like a problem with your switches you can unplug the small black wire by the cdi box and that will eliminate any problem with a switch but you will have to plug it back in to shut the wheeler off. Hope this helps, Happy Hunting [img]i/expressions/face-icon-small-smile.gif[/img]
