polaris 300 xplorer
Old Feb 8, 2007 | 03:49 PM
bob567's Avatar
Default polaris 300 xplorer
I have a 96 300 explorer and when I start it, it will run for a short time then stops. is this a carb problem or is something else,any ideas or suggetions if you have any would you please help me out with this
thank you
bob
Old Feb 8, 2007 | 03:52 PM
scrammersam's Avatar
it could be the carb, wouldnt hurt to clean it. are you sure the gas is turned on or that there is gas in it?
Old Feb 8, 2007 | 04:06 PM
bob567's Avatar
yeah theres gas in it and its on put your thinking along the lines of the way it is acting is there a coil that can go bad thanks for your input
bob
Old Feb 8, 2007 | 11:28 PM
ftwflh's Avatar
Sounds like you may have a pinched or plugged vent line on your gas tank.Start it with the gas cap off and see if it still dies.Or when it starts to die loose the cap up.If this helps check the line.
Old Feb 23, 2007 | 12:30 AM
JDO's Avatar
JDO
Hey I've been looking for a 300 xplorer to buy. What kind of shape is it in?
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
cornermike
Jul 30, 2015 06:37 AM
cornermike
Jul 8, 2015 11:44 PM
