No power SP700?????
Old Feb 14, 2007 | 06:53 AM
Speeddrive1's Avatar
Default No power SP700?????
Remove the seat, side panels, air box, filter, rear carb mount bracket, fuel line, throttle cable and choke cable, vent lines, intake boot clamp. Slide carb back and out. Remove the intake boot and check for cracks.
Old Feb 14, 2007 | 07:59 AM
Sportsman700Twin's Avatar
Dumb question, but how do the cables come off the carb?
Old Feb 14, 2007 | 06:56 PM
The choke cable screws in from the side, a plastic nut with the cable going thru the center. the throttle cable goes in from the top. You can wait and remove that one once the carb is out easier to get at.
Old Feb 14, 2007 | 07:38 PM
jta4455's Avatar
speeddrive is right check the carb adapter as they crack sometimes causing a lean condition. You can clean the carb with the cables on, this is how i do it.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
